Bernoulli's Theorem in Valves
**I WORK IN A POWER PLANT WITH LOTS OF VALVES SO I AM TRYING TO UNDERSTAND ALL THE THEORY**
We say that according to Bernoulli's, there is an increase in velocity of process fluid in a valve which results in a pressure drop as potential energy is converted to kinetic energy due to the constriction.
1) That makes sense theoretically, but I don't get how there is low pressure at the vena contracta, if its the fastest velocity shouldn't it be high pressure?
2) And then how do waterjet cutters work? Don't they concentrate water such that it is both high pressure and velocity?
RE: Bernoulli's Theorem in Valves
