Volt Free Contact
Volt Free Contact
Does remote start/stop of equipment is possible through volt free (Dry) contacts provided in equipments' control panel? I want to start/stop the pump through BMS. Manufacturer states that he has provided Volt free contacts for start/stop in pump's control panel.
RE: Volt Free Contact
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
But our engineer says, volt free contacts are for taking status only. You cant provide command via volt free contacts. Any advise pls.
xnuke
As noted above you need to know what the contacts need in order to make the contact - 12VDc or 240V AC or something else and maximum current the contacts can take.
Simply saying there are a pair of contacts here which start / stop the pump without giving you the voltage and current rating is next to useless.
Also is the relay latched or does the pump stop on loss of volts?
xnuke
