Drafting - View Frame size
4
Is it possible to extend/reduce the frame of the view?
I was looking for that in the Option. but I couldn't find anything.......
Also, how could I set up the shape of the dimension's arrow to filled arrow, before I start dimensioning?
CAD 2015
RE: Drafting - View Frame size
From my experience, the answer to your first question is no. I found it to be really strange as drawing will never fit perfectly in window in case one view frame is outside thedrawing area.
The answer to your second second is that there is somewhere a XML file where you could pre define all values and it will be taken I to account for all new drawings.
Thank you all!
2thumbsup
CAD 2015
To expand on what was previously said about View Frames...
The Frame size is automatically determined by the 3D part/assembly and cannot be extended, but the view can be cropped to reduce the frame size.
(assume you are not asking about the view Scale)
Thanks, Jackk!
bigsmile
CAD 2015
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Understanding Critical Specifications for Dynamic Metrology Applications
Different types of metrology have different critical specifications to consider when determining which actuator technology to use. This white paper goes into detail on the demands of dynamic metrology applications as they apply to the selection of precision linear motion control components and systems. In addition, the relevance of Moore's Law is examined in the context of the industry. Download Now
White Paper - Permanent Non-Welded and Cold Bent Piping Solutions
Commonly used welded piping connections come with skilled labor, validation, inspection, and long commissioning times, as well as the workplace hazards associated with welding. Non-welded permanent mechanically attached fittings offer a viable alternative to welded piping systems that greatly reduces the time to commission piping systems through reductions in many of the time-consuming steps required in welding. Download Now
White Paper - Take Mobile Hydraulic Systems to a New Level
The introduction of digital ecosystems connecting electronic control hardware and software to the Cloud is catalyzing a new era of mobile machine and equipment design innovation. This is enabling OEMs across industries to develop customized solutions that digitally integrate hydraulic and machine controls with the Internet of Things (IoT). Download Now
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
