Bolt issue
Bolt issue
In our work site we have a problem in the standard bolt way, when removing the shell end cover for the tube inspection on the Exchanger equipment during a inspection work activities, we continuously encounter problems releasing the nuts from the Bolt stud (welded and cut off).
These exchangers operate at high temperature ( between 160 to 280 Co) which causes the Bolt Studs and Nuts to fuse together & the only way to operate them is to cut the Bolt Stud.
The specification of these Bolts 1" 1/8 x440 mm (A320 GR L7)/ 2H (A194 GR 4).
Waiting your feedback ASAP.
Thank you in advance.
RE: Bolt issue
RE: Bolt issue
I'm new joined.
I don't have a good experience in this work site.
Thank you for the note.
RE: Bolt issue
https://www.bing.com/search?q=high+temperature+ant...
A lot of products are available to minimize thread seizing and galling. 280-C is not expected to "fuse-together" a bolt/stud and nut.
Walt
RE: Bolt issue
(2B)+(2B)' ?
