Overstressing a bridge
Just watched this video and was surprised about how much you can overstress some structural elements without causing failure:
https://youtu.be/eHxvj7C0OT8
RE: Overstressing a bridge
Nice video but it may not be overstressed. The bridge uses a shallow stiffening girder as opposed to a stiffening truss; that's why you see pronounced deflections.
Arkansas Highway Department has a website with old bridge plans; I'm going to look to see if this one is in there.
Link
bridgebuster, interesting link. Just wondering what is the oldest bridge in that list...
Okiryu - I found that link a few years ago and downloaded some plans. A lot of stuff from the 30's; don't recall if I found anything earlier.
Here are the bridge plans:
Link
A Wikipedia link:
Link
I thought a suspension bridge was supposed to deflect; otherwise, the beams would be carrying the load and not the cables.
We lived up in Colorado years ago and went up to the Royal Gorge bridge. I was talking to an elderly lady about that later, and she said back when they built it, the wind deflections would move the bridge enough that, standing at one end, you couldn't see vehicles at the other end. She said they added additional stiffening cables later. When we were there, watching closely, it looked it was slowly swaying up and down about a foot from the wind. You couldn't really tell it was moving when you were out on it.
When I was a kid, the bridge across the intracoastal canal going out to Quintana beach was a floating bridge- basically a barge. I drove a bobtail dump truck across that one time, and it seemed the end went down about a foot when I drove on. My dad said with the trailer dumps, the operator would come out and motion them to take it right down the middle.
Of course it deflects. The depth of the stiffening girder/truss affects the amount of deflection.
Wikipedia article notes bridge was pedestrian and cycles. Also noted bridge was temporarily closed this month because two overloaded buses went over it.
The weight limit is 10 tons. A story said the bus was 35 tons.
I think the bus is more likely 35,000 lbs- figuring 8 wheels at 80,000/18 lbs per wheel.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Design for Additive Manufacturing
With a growing number of parts manufactured directly by additive manufacturing techniques, it is important to lay down design principles suitable for such manufacturing processes and to ensure parts are designed for additive manufacturing. There are several factors that are to be considered at the design stage. Few such design issues in additive manufacturing are discussed in this paper. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
