understanding mass participation
hi,
I am trying to understand basics of mass participation factor.
My questions are:
1-could someone help me figure out why sum of effective mass of all modes equals the total mass of the system.
2-the higher the mass participation factor the more the mode contribute in total response.why?
RE: understanding mass participation
Quote (OP)
Because, when all is said and done, the entire mass of the system must be accounted for in order for the technique to be valid. It wouldn't make any sense for a portion of the system mass to simply not participate in the vibratory response, right? We designed the technique to have this aspect of conservation built into it.
Quote (OP)
It's kind of a chicken and egg thing. We devised the technique specifically so that we would know how much each mode of vibration contributes to total response. And, low and behold, the technique does allow us to know how much each mode of vibration contributes to total response.
Your questions are a bit irrational in the sense that you're effectively asking:
Why does this mathematical technique designed to do [A & B] do [A & B]? The technique does [A & B] because we formulated it to do [A & B]. When you think of it that way, it's self evident. It's a bit like why asking why 2 + 3 = 5 or why 3 > 2. Those things are true because we formulated or system of mathematics such that they would be.
I don't mean for any of this to be condescending. I simply think that you need to see things in this light in order to recognize that these techniques are man made formulations designed to produce exactly the results that you're questioning.
I only know the formula of mass participation factor.but how defining it in this way makes it sum up to total mass I could not prove it and this is the problem.and same for my second question.I mean modal participation factor is visible in the differential equations but mass participation factor is not.so it makes sense that the higher the modal participation factor is,the larger the amplitude of the mode.but for mass participation i couldnt prove it.
Maybe you are not considering all the modes possible for your structure. You have likely made an error, and you have not given any information regarding what you have done except 'it doesn't work'. Try a simple structure with 2-3 modes to minimise the chance of errors and see if it works.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Integrating the Engineering Ecosystem
Aras Innovator provides multiple options for integrating data between systems, depending on the scenario. Utilizing the right approach to meet specific business requirements is vital. These needs range from authoring tools, federating data from various and dissimilar databases, and triggering processes and workflows. Download Now
Research Report - Simulation-Driven Design for SOLIDWORKS Users
In this engineering.com research report, we discuss the rising role of simulation and the paradigm shift commonly called the democratization of simulation. In particular, we focus on how SOLIDWORKS users can take advantage of simulation-driven design through two analysis tools: SOLIDWORKS Simulation and 3DEXPERIENCE WORKS. Download Now
White Paper - Industry 4.0 and the Future of Engineering Education
With industries becoming more automated, more tech-driven and more complex, engineers need to keep their skills and knowledge up to date in order to stay on top of this wave—and to be prepared for the Industry 4.0 future. The University of Cincinnati offers two online Master of Engineering degree programs designed specifically for practicing engineers. Download Now
eBook - The Design Gridlock Manifesto
In this eBook, you’ll learn 6 ways old CAD technology slows your company down and hear how design teams have put those problems to rest. “The Design Gridlock Manifesto” shares first-hand modern CAD experiences from 15 companies around the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
