We have a magnetic component that is blanked from AISI 8620 which we vacuum anneal for magnetic properties prior to gaseous nitrocarburizing to give it a hard case. This whole process was developed initially for similar parts made from 2.5% silicon iron which has worked well for 30+ years. However, I designed a new application that is more sever and the silicon iron proved to be too brittle, pure electrical iron was no better. So I changed the steel to 8620 for the new application and it has passed all our testing and been in volume production for a couple of years with no failures. I made no changes to the anneal and heat treatment specifications which we do in-house. I should note that staff metallurgists who wrote the specs have long since retired and the company has not seen fit to hire any replacements.
Recently we have increased production and the plant manager has asked purchasing and manufacturing to get outside heat treatment sources approved. The outside anneal supplier did not follow our spec which calls for 1 micron of mercury vacuum during the heating and soaking periods of the cycle. Instead, they used 100 microns of mercury vacuum. I can see no change in properties or performance from this but would appreciate someone with a bit of formal training in this area to opine before I approve it.
