How to make Compound Frame GD&T in NX11
I am trying to make a compound tolerance frame in NX11 but when I use the GDT tool that's available there's a space between the two frames. Recently I've been using the Text tool for a single frame with text under it. My question is, is there a way to create a compound tolerance frame using the text tool to eliminate the space in between frames? I've attached a power-point illustrating further details.
RE: How to make Compound Frame GD&T in NX11
<&70><+><&10><+><O>3.0<M><+>A<+>B<M><+>C<M><+><&80><+><&8><+><O>0.5<M><+>G<+><&90>
If you create the second one and move it onto the first they should snap together.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
