Contact US
RTV silicone rubber
RTV silicone rubber
RTV silicone rubber
Hello guys,
can you give me advise about RTV silicone rubber?
What what can dissolve RTV silicone rubber?
RE: RTV silicone rubber
silicone oils.
Uncured silicone will dissolve in naphtha and probably acetone. Once cured, silicone will not dissolve but it will swell and become much weaker and easier to rub off.
Dichloromethane degrades silicone so it readily breaks up using mechanical means, however it also attacks light metals and almost all organic materials, plus it's a probable carcinogen.
Dichloromethane do not working
@ScottyUK do not work
How long did you leave it? I'm not aware of anything which breaks down RTV immediately, you will need to leave it to soak for an extended period until the RTV starts to swell and weaken.
@ScottyUK it was about 8 hours. From fisrt 2 hours RTV swell and weaken than nothimk happent.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
