oil pump relief valve
what is the function of the oil pump internal relief valve when there is a separate relief valve (circled)after the pump connected to the main gallery? is it just added redundancy?
TIA
RE: oil pump relief valve
The internal one may just be to protect the pump itself under certain scenarios. The external one may be to protect the engine?
Is the oil filter connected between the primary and secondary relief valves?
I once had a jammed pressure relief valve that would release and work normally when the engine warmed up.
Starting on a cold morning, the high oil pressure blew out the filter seal ring.
Bill
"Why not the best?"
Jimmy Carter
White Paper: Industrial Control Basics: Contactors
A contactor is an electrical device used for switching an electrical circuit on or off. Considered to be a special type of relay, contactors are used in applications with higher current carrying capacity, while relays are used for lower current applications. Download Now
Research Report: State of IoT Adoption in Product Development 2019
This research report, based on a survey of 234 product development professionals, examines the current state of Internet of Things (IoT) adoption by product design teams, its perceived importance, and what features and capabilities teams consider important when making decision about adding IoT functionality to their products. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
