Undrained Strength Ratio from CU Triaxial
Hi all,
Can someone please enlighten me as to the correct way of calculating the undrained strength ratio (Su/σv0’) from the results of CU (compression) triaxial tests?
Not a single textbook or course notes I have seen actually describes how to do this, yet all the time in the literature you see Su/σv0’ values which have been derived from Tx results.
I know that one is able to get the friction angle (phi) and cohesion in total stress terms from the CU test. In a NC clay this envelope is supposed to pass through the origin. So, if the ΦT is 20°, can I convert this to a Su/σv’ by tan 20° = 0.36?
Or is the more correct thing to do to look at the stress path in q-p’ space (or t-s space) and select the maximum shear stress divided by the consolidation effective stress (σ3 at the end of consolidation/ start of the shearing phase)? This would seem more correct than the first approach since you might have contractive behaviour (as in the attached) in which case the peak shear strength for a given consolidation stress will be lower than the Mohr-Coulomb envelope suggests.
By the way, quite a few textbooks will explain the strength parameters in terms of total stress but will then go on to say that it is seldom used in practice. Also, confusingly a lot of textbooks refer to this as the TOTAL STRESS strength rather than UNDRAINED strength and then call the results of UU tests undrained, as if there is some kind of important distinction to be made (which they never go on to make). Is it incorrect to call the strength from a CU test an undrained strength? After all, the test is most certainly undrained.
RE: Undrained Strength Ratio from CU Triaxial
Generally you cannot use the friction angle to get the undrained shear strength (su). This is because su is equal to the deviator stress at failure (qf) divided by 2 (think of a Mohr circle), which is affected by the pore-water pressure (i.e. contractant versus dilatant behaviour during undrained shearing, as you note).
As for σ'v0 in the test, that is the vertical effective stress at the start of shearing (= end of the final consolidation stage). Using σ'v0 is probably not the best normalising parameter for overconsolidated or anisotropic materials, however (the mean effective stress, p'0 or σ'm, would be better).
Undrained tests can be used to obtain effective stress (and total stress) parameters if you measure the pore-water pressure. This is because you are able to calculate what the effective stresses are, so can plot the effective stress path. As an aside, increasingly engineers appear to be scheduling UU triaxials with pore-water pressure measurement as a 'cheap' alternative to doing a full CU test. This penny-pinching practice is utterly ridiculous and indicative of engineers who haven't got a clue what they are doing with respect to lab testing.
To be honest I never really liked the 'total stress = undrained' and 'effective stress = drained' definitions. It's just confusing. Whenever you think of drained or undrained behaviour, just think of critical state soil mechanics: is it constant volume (undrained) or constant stress (drained)?
A CU-bar is typically performed at three confinements. Each confinement is consolidated to some load, the drainage is turned off and the sample is sheared. You get a total stress for failure and you get a pore pressure that accompanies that failure.
Ignoring the pore pressures, you'll have a maximum deviator stress for each consolidation load (i.e., for each P'). That's your Su.
f-d
ípapß gordo ainÆt no madre flaca!
There's no need to undertake multiple CU tests as you can define the critical state line with a single CU test which is sheared to sufficiently large strain to reach critical state. Likewise, plotting Mohr circles is anachronistic: the full stress path from a single test is much more useful and relevant, especially if the strain level is noted at certain points on the stress path.
Thanks for the help everyone. Much appreciated!
Although I do still wonder if one should be very clear about saying the MAXIMUM deviator stress divided by 2, or the final deviator stress divided by 2 when the stress path reaches the critical state (I think this is what LRJ means by "deviator stress at failure"), because in the case of a contractive sample that deviator stress is lower than the deviator stress at the collapse surface (which would be the peak deviator stress), and must surely be the true undrained strength of the sample. Its hard to put that in words without an illustration to go with it, but I imagine you know what I mean.
if the point is to get the Su/P ratio, you'd need multiple points. The PvQ drawing can't get you there. Well, maybe I'm missing something?
f-d
Ah yes, for su/σ'v0 you are right that you'd need multiple tests. But you don't need multiple tests to define the friction angle with an effective stress path triaxial test.
I agree that there is a relationship between phi and alpha. I was just reacting to the question about undrained shear strength.
f-d
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
