Revit trial, 3D grahic blurry, see attached image
I installed Revit 2018 for a month trial. The 3D view is blurry and when I insert a door the following
error message occurred:
"None of the created elements are visible in 3D View: {3D} View. You may want to check the active view, its Parameters,
and Visibility settings."
Since hours I try to find the way to repair this. No success.
Have one of you an idea?
See image. Thx
RE: Revit trial, 3D grahic blurry, see attached image
Your view settings are not set correctly.
And without a more detailed description i would recommend first to type "VG" and make sure doors check box is checked.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Considerations for choosing a 3D printing technology
The adoption of 3D printing into major companies’ product development life cycles is a testament to the technology’s incredible benefits to consumers, designers, engineers and manufacturers. While traditional production methods have limitations in manufacturability, 3D printing provides unparalleled design freedom due to the additive method of building parts layer by layer. Download Now
White Paper - Are all 3D printed metals the same?
With so many different 3D printing metal systems and processes today, how can you know exactly what you’re getting? Today, there are several different methods for manufacturing 3D printed metal components with their own strengths and limits. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
