Contact US
Drain Valves
Drain Valves
Drain Valves
Could anybody help me in selecting good Drain Valves for thermal power plant.
RE: Drain Valves
Isha90,
More information would help!
- What is the Commodity?
- What it the Design Pressure?
- What is the Design Temperature?
- What is the Line or Nozzle size?
- Will this Valve be manual or actuator operated?
Is there any more information we should know?
Sometimes its possible to do all the right things and still get bad results
RE: Drain Valves
Additional thoughts:
- What type of the valve is specified in the current Piping Spec or used in the existing power plant?
- Is there any issue of the drain valve in the plant?
RE: Drain Valves
Thank you, T type Globe leaking, Operating temperature 596-617°C, pressure 60 bar, Line size <2", both manual & actuator operated.
RE: Drain Valves
How often is the piping drained. I guess only once a year for maintenance. Therefore actuated operated valves are not really nessacary. DN50 is normally large enough for drains, depending on DN of pipes you should also think of installing vents to support the draining. Instead of globe a gate, butterlfy or ball are more convenient for draining since the kv-value is much higher. Seals must resist temperature and medium.
RE: Drain Valves
Thank you
RE: Drain Valves
Please note that some drain valves in thermal power plants must be power actuated to prevent water induction into the steam turbine. See ASME TDP-1 for the latest requirements for drains.
Best of luck!
RE: Drain Valves
Thank you, Please advice/recommend how to select drain valves, any article/book available there to learn
RE: Drain Valves
As far as I remember we always used ball valves DN25 with blind flange at the end to prevent against loses in case of leackage. Ball valves are small, cheap and can make a good end connection when flanged or screwed.
RE: Drain Valves
Drain valves for steam lines in a thermal power plant are a special application since pressure drops across the valves can be very high (considered as "severe service"). I suggest that you move this post to the Power generating facility forum to get more appropriate responses.
Best of luck!
RE: Drain Valves
Thank you
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
