ACT Console - Create Named Selection, Mechanical (Criterion: Body Name containing specific string) 1
smhrjn
3
Dear All,
could anyone suggest me, how to create Named Selection in Ansys Mechanical using ACT Console. Named Selection should use worksheet (Entity Type: Body, Criterion: Name, Operator: Contains, Value: 'String).
It would speed up NS generation, as I import geometry from Spaceclaim named accordingly.
Thanking you,
Sarat
Python:
model = ExtAPI.DataModel.Project.Model
analysis = model.Analyses[0]
solution = analysis.Solution
workingdir = analysis.WorkingDir
named = model.AddNamedSelection()
named.Name = "Named Selection"
named.Location = ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.WorksheetSpecific)
worksheet = named.Location
worksheet.AddRow()
worksheet.SetEntityType(0,NamedSelectionWorksheetEntityType.Body)
worksheet.SetCriterion(0,NamedSelectionWorksheetCriterion.Name)
worksheet.SetOperator(0,NamedSelectionWorksheetOperator.Contains)
worksheet.SetStringValue(0, "String")
Maybe this will get you started. The criterion line does not work yet and I don't know why. It accepts other criteria. This link
might also be useful.
Thank you L_K for your reply.
main Problem I had was exactly NamedSelectionWorksheetCriterion.Name. I could not find anything on Internet or any official documentation.
Thank you very much L_K. It works great.
I don't have access to customer portal currently but "NameProperty" was enough to solve my problem.
