Contact US
Is "overlength" an actual English term?
I want to place a remark on my piping drawing that the contractor needs to order slightly longer (+100mm) pipes, due to inaccurate measurements in the field. In Dutch we use words like "paslengte" or "overlengte" to explain this, but I don't know the correct English translation. Can I use the word "overlength" for this purpose? Or isn't that an actual word?
RE: Is "overlength" an actual English term?
"Overage" is.
Or just add a note as marked on the drawing saying exactly that i.e.
"Contractor to add min of xxmm to pipe lengths to allow for field fit measurements. All lengths noted are nominal and must be field checked by contractor before purchase and construction"
I'd call this "contingency".
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Thanks for the replies guys!
Although, as there seems to be no uniform term for this (on another forum somebody suggested "trim allowance"), it looks like I discovered a shortcoming in the English language bigsmile
Many shortcomings (is this an English word), however to clarify "overlength" - this would be used and understood if a pipe was ordered as "X" length but supplied longer than specified, you would say - overlength.
That's not a shortcoming, but is the English languages flexibility at work. There are often more than one or two or three ways of saying the same or similar things.
It's kept lawyers in work for centuries.....
Sirrah: how about only posting in one thread as per Engtips directives.
the below image may be of help . . .
"Excess"
Mike McCann, PE, SE (WA)
Some spell check dictionaries accept "overlength"
Some spell check dictionaries (including the dictionary I am presently using) accept "over-length"
Bill
"Why not the best?"
Jimmy Carter
You can, on the drawing, indicate an overlength with a superscript or other type of marker indicating a notation on the drawing for the field contractor to trim to the appropriate length during fit up.
Thanks for all replies guys. Multiple options to choose from then thumbsup2
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
