Dibastidas
Hi friends,
My team and I are developing a study to climatized several areas in a warehouse building in Peru. In one of the areas we are recomending a Carrier VRF unit Outdoor model: 38VR006H113010 (53100 BTU) that will supply 2 High wall units model: 42VH024H113000100 (24200 BTU/EACH. Originally we had in our AFCs the condenser unit located in the exterior of the building, nevertheless the construction team is suggesting putting the unit inside the warehouse, considering that the interior temperature of the building is aroung 31°C in the summer and averages around 22°c year round with the lowest being 19°C. Now, generally speaking is not recommended to place an outdoor unit in an inside area. So as an engneering team we are recommending maintaining the condenser unit in the outdoor of the building unless it is not possible. So it will allow the unit to have an unlimited access to outdoor air which is important for a good air flow and performance, preventing the inside of the building to be affected by the heat exchange process between the indoor and outdoor unit, placing the condenser unit indoors will reduce the system’s air supply, which will limit the amount of heat that is able to remove from the pantry/commissary area. Locating the unit inside required a study of existing exhaust and make-up air system in the warehouse in order to guarantee a proper air flow.
The outdoor temperature averages are:
• Warm Season Average daily high temperature: 81°F (27.22 °C), low temperature: 69°F (20.55°C)
• Cool Season Average high temperature: 66°F (18.88 °C), low temperature: 59°F (15°C)
I'm having a hard time to find the applicable code that mentions that the condenser unit should be outdoors.
Does anyone have the code or any recommendation about this issue?
