Contact US
Trying to get info for a datum plane crashes Creo
Hello.
I have had this problem for some years and usually just brushed it off. Now, I need to do this and it appears to be a bug in Creo2.0. If I create a datum plane, and then try to do right-click > Info > Feature, Creo crashes. Has anyone else seen this problem? I thought it might be my personal config.pro file with old remnants from Wildfire, but even if I use Creo's default config.pro file, the same thing happens.
Any guidance on this would be super!
RE: Trying to get info for a datum plane crashes Creo
What build of Creo 2.0 are you using?
when Wildfire 1 was released as pre-release version C000, I could build a cube and the software would crash when I went to complete the steps.
Ben Loosli
Thanks for replying, looslib.
Creo 2.0 M100
Info-Feature on a select plane created in Creo2 m250 works fine.
Can you upgrade to a newer release?
Ben Loosli
If you have support from PTC just submit a case to them. I think Creo 2 is still supported.
Great tips, guys. I guess it's time to upgrade!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
