Maximum particle size -Triaxial
Hello all,
According to the ASTM D4767, the maximum particle size for the triaxial specimen should be less than 1/6 diameter. Can you share your experiences about this, whay sieve do you use for a 2.8'' remoulded specimen and 4'' remoulded specimen.
I would appreciate your comments.
Best regards,
Cristina
RE: Maximum particle size -Triaxial
One reply. My need for triaxial tests was quite limited and besides, the cost of an elaborate group of test gear had to be balanced against need. The only triaxial tests I did were on undisturbed mostly clay samples from 2" and 3" Shelby tubes. I saw no need for using disturbed samples. This is from my experience on many hundred jobs of many types. Generally little or no gravel content for the test sample.
Triaxial tests can be performed on any gradation....the ASTM standard is for general soil conditions....rock triaxials are common.
I agree with Ron and oldestguy. /i should also note that depending on the project, if you have substantial budget, a large triaxial cell can be used. I used a large triaxial chamber once for a mega dam project and the cell was almost 0.6 m tall! a huge cell and such an expensive test.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
