Cannot Expand Menus in NX
I am unable to slide the menu part of the Settings dialog boxes open to read all my options. The mouse pointer doesn't turn into the 2-way pointer that would normally enable me to slide it open. I've attached a screen shot of what I'm seeing. It's the menu to the right I can't get to be bigger. Anybody?
RE: Cannot Expand Menus in NX
Tested in NX11.0.2. I have the same behavior. When there are entries in the left column which do not fit a scrollbar appears at the bottom.
My guess is that this is o.o.t.b behavior. Pretty annoying though I must say.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
I tried to increase to increase the dialog box width within the Utilities. You have to restart the NX session which I did. No dice. I've also attached a screen shot of another little annoying thing I've been running into.
I should add that I am working from a laptop with Windows 10 if that makes a difference.
Everything was fine and I came in one Monday and all these weird things were happening all of a sudden. I guess I just have to work with it and hope that the people that create this stuff will work these things out.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Close Box
Join Eng-Tips® Today!
Join Us             Close
