Vibrating wire piezometer dry
Hi, I have to install an array of VWP's along the base of an old opencut quarry (approx. 90m deep)that is going to be filled with engineered fill. (houses built above) there will be there to monitor the infiltration rate and pore pressures. The only problem is that the Piezometers I am used to all need water in the filter during installation. It might be months before the water table (if it ever does) infiltrates to the VWP's (laid in a trench). And am concerned that they will dry out and when the water does eventually get to the VWP's the air bubble between the mesh and the sensor will remain and the data will be useless. will water eventually soak in through the Mesh (steel or ceramic)??(I didn't think it would)Ideas??
RE: Vibrating wire piezometer dry
Air bubbles will not affect the reading. The pressure in an air bubble is equal to the water pressure surrounding the bubble. But if the soil is dry, there is no pore pressure.
Thanks for the reply. I have just been told that it could take up to a year for the water table to interact with the VWPs. So I was worried that if the VWP's small reservoir of water dried through capillary action or other action that when the WT eventually came that the data would be not accurate.
Drying of the filter stone is a problem. One option would be to grout the piezometer in-place.
I suggest you talk with the manufacture and get their suggestion(s).
Mike Lambert
Place the piezometer in the water tank covered by geotextile and sandy gravel to avoid clogging.
Thanks for the replies. I'll keep updating with my progress. Cheers
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
