I'm a recent grad and relatively new to the automotive industry. I've been given an outer race for a one way roller clutch as one of my first projects. I'm hoping someone here may have some insight that may help me. One of my primary concerns for failure of the race is from the hoop stress from the rollers. I've researched a bit and found the equations for hoop stress at the loads and between the loads from Timoshenko's Strength of Materials. I'm having some difficulty determining how to apply these to get useful numbers that will best reflect the real-world stresses.
The calculations for hoop stress are derived from a cross section of the race. Since the race I am designing needs to have an oil collector groove, (kinda similar to the 4T80E race), the cross sectional area will not be a regular geometry. Additionally the rollers will only directly apply pressure against maybe 2/3 of the width of the race. Should the cross section I am using to determine the stress, include just the area that would be on the directly on the path of the roller, or the full area of the cross section of the race. The numbers depend a lot on the neutral axis, so it is hard for me to determine if it will be more accurate to analyze the complete area at the cross section, or just the area directly under the load from the rollers? Or determine the neutral axis just from the cross sectional area directly on the roller path, and then apply that to the entire cross section?
Apologies if this is unclear. If anyone has any insight that could help it would be very much appreciated.
Thank you
Thank you
