waytsh
- Jun 10, 2004
- 384
I have noticed that home builders in my area are using a continuous LVL header for the entire length of garage wall with multiple doors. Does anyone know if this is a code requirement? I understand the need to maintain a continuous load path from endwall to endwall so that all the portal frames around the doors can be engaged but is this the typical method to accomplish this? The methods I see in the AWC documents seem to show breaking the header.
