Grinding wheel specs
Filippo320
Industrial
IT
Hello all,
I just found this interesting forum and I would like to submit a question.
I'm having trouble figuring out the spec of a small internal CBN grinding wheel.
On the drawing of this Bahmueller tool the only note I have is "B35VPM1-AS67239"
Can I recognize from the code above what's the grade of this tool? I have to traduce the spec in something like "CB325Q200VN1" where Q is the hardness.
Thank you in advance for any tip.
