MAX. PENETRATION, MAX. CONTACT FORCE ERROR and NEGATIVE EIGENVALUES
I'm doing a simulation in abaqus standard and i wont to know if MAX. PENETRATION, MAX. CONTACT FORCE ERROR and NEGATIVE EIGENVALUES is a problem or i can stay with them? If yes, how can i fix them and how they afect my results.
Some exemples:
"***WARNING: THE SYSTEM MATRIX HAS 23 NEGATIVE EIGENVALUES."
"MAX. PENETRATION ERROR 2.51836E-09 AT NODE SUPORTEPE-31-1.904 OF CONTACT
PAIR (ASSEMBLY_S_SURF-822,ASSEMBLY_M_SURF-849)
MAX. CONTACT FORCE ERROR -77.7828E-06 AT NODE SUPORTEPE-32-1.379 OF CONTACT
PAIR (ASSEMBLY_S_SURF-701,ASSEMBLY_M_SURF-704)
THE ESTIMATED CONTACT FORCE ERROR IS OUTSIDE OF CONVERGENCE TOLERANCES."
"MAX. PENETRATION ERROR 40.3043E-09 AT NODE SUPORTEPE-25-1.20 OF CONTACT
PAIR (ASSEMBLY_S_SURF-829,ASSEMBLY_M_SURF-828)
MAX. CONTACT FORCE ERROR 794.025E-06 AT NODE SUPORTEPE-23-1.10226 OF
CONTACT PAIR (ASSEMBLY_S_SURF-572,ASSEMBLY_M_SURF-842)
PENETRATION ERROR TOO LARGE COMPARED TO DISPLACEMENT INCREMENT."
Thank you.
RE: MAX. PENETRATION, MAX. CONTACT FORCE ERROR and NEGATIVE EIGENVALUES
If the analysis find convergence in later iterations and the results look plausible, then you don't have to worry.
Okey, Thanks!
White Paper: Rapid Manufacturing with FDM
The automotive industry is increasingly turning to additive manufacturing, and fused deposition modeling (FDM) specifically, as a reliable alternative to traditional metal-cutting methods, like milling, turning and boring. Download Now
White Paper: Revolution in Design
Open up new possibilities for your business by changing the way you think about product development. Compared to traditional methods, 3D printing offers advantages that allow you to make more innovative products and get them to market faster. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
