aardy_wolf
I work at a firm where we design crane plans (mainly mobile cranes, however we do some tower crane, suspended scaffolds, mast climbers, and pile drivers) and one of the main design considerations is the presence of voided/vaulted spaces below grade. We usually follow the 1:1 (also known as 45 degrees) ratio rule when operating near foundation walls. This usually means that we keep the distance (as seen from plan view) from the outer edge of the crane's outriggers (and if it's sitting on dunnage/plate, the outer edge of that) to the edge of the foundation wall equal to the height of said foundation wall. So for example, if the basement of a building has a depth of 10', we usually restrict the crane's outriggers to a 10' minimum distance away from the foundation wall, as seen from plan view, in order to avoid impact to the foundation wall.
However, a very important question came up amongst my team regarding the impact that the crane loads have on the footing. Since many of the buildings in our jurisdiction are old (majority are pre 1930s), we do not have all the details for the foundation wall design or footing design, so an analysis is difficult to do (however we do analysis with conservative assumptions when required). So we usually just follow the 1:1 ratio rule as a good standard of practice (and if 1:1 distance cannot be maintained, we do impact calcs to see if foundation wall can sustain crane loads). Following the example as stated in the previous paragraph, lets assume the depth of the vaulted space (e.g. basement) is 10'. Without plans or specifications, we do not know the depth of the footing. So if we were to limit the crane's outriggers to a minimum distance of 10', the impact from the crane loads would technically be impacting the footing. For simplicity sake, lets assume the footing is 1' deep. My questions is:
I would assume that the crane loads truly impact the footing, but that the impact is negligible at best due to the fact that there is usually a slab adjacent to the footing (imagine a section view of the foundation wall) which provides the footing with more strength to resist lateral loads. Since the slab is also acting as a diaphragm, and that there are no voids to either side of the footing (imagine a section view of the footing, with the left side being the slab and the right side being soil), the footing is acting primarily as a member of the buildings' foundation to support the foundation walls in bearing. I doubt that footings are designed with lateral loading in mind, however I am not that well versed in footing design and considerations. I of course would prefer the most conservative practice when developing crane plans and would like to avoid impacting the footing.
Any help would be wonderful!
Just looking for opinions, as my background is not in foundations, but is primarily structural. Please let me know if I phrased anything incorrectly or if I could have phrased it better or shorter, as I wish to improve my technical writing.
a) Is the crane loads really impacting the footing? and
b) If so, how can the impact to the footing be measured? For impact to foundations walls, we usually follow a terzaghi method to find the lateral loads and then compare that to the design strength of the foundation wall. Would we follow a similar method? and
c) What would be a safe assumption for the depth (or height) of a footing? I know there are many answers to this, but assume a building height of around 6 stories (or 60 feet) designed and built around the 1930s
