HELP with ABAQUS Subroutine to change element material properties
Hi, I'm trying to do a subroutine that works as follow: I want to introduce a temperature limit condition to each element of my model. If the element reach a temperature value, I want to change its electrical conductivity properties. (I'm doing a Coupled thermal-electrical analysis)
Which type of Abaqus Subroutine I have to use? UEL, HETVAL...?
Thank you!
RE: HELP with ABAQUS Subroutine to change element material properties
Not sure which one to use, or how to do this, but have you considered just using the standard temperature dependent properties (e.g., electrical conductivity), within CAE?
For instance if the electrical conductivity becomes twice as large (200 from 100) at a certain temperature (say 100 degrees), thus a step function, then one could give the following table for the temperature dependent electrical conductivity in CAE:
El.C Temp
100 0
100 100
200 100.01
200 1000
This will be valid for all elements using this material property.
Yeah, the built-in option should be checked before.
In case a subroutine is really needed, then I would look at the USDFLD and the usage of field variables.
As always, the manual explains the details.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
