How to get flexural stress of a plate modeled counterfort?
Hi guys. I am trying to make a STAAD model a counterfort geometry as per my attached sketch, but then i was stucked when i was trying to find my bending moment for the cantilever behavior of of the counterfort. Any way staad could give me the stress i wanted?
RE: How to get flexural stress of a plate modeled counterfort?
You say the counterforts are plate elements.....but looking at your mesh, that looks more like solid elements to me.
In any case, finding the moments for plate elements is pretty straight forward. In post-processing, you click on the plate tab and the values should come up in (on the right hand side of the screen) in spreadsheet format.
Hi WARose, it were plates,i modeled if myself. As with your reply that forces are just there (straight forward), you might be telling the out of plane stresses (Mx, My Mxy). But please take note that the counterforts were in plane with the main wall forces, and this is not what i need to have.
If you are talking in-plane behavior.....you can get principal stresses in the output. If you want to find the overturning moment at the base.......you can figure that from the reactions.
Did you let the program mesh that for you. Because it's not a very good mesh. I'd consider going back and meshing it by hand. Then at least you could guarantee that your local axes line up better. Then looking Fx and Fy should give you a pretty good idea of compressive or tensile stresses in the plates relative to their local axes. That should be pretty close to what you're looking for I would think.
Hi Josh, i actually had the automatic meshing for the counterfort just to take its stiffness effect, as i was only taking the stresses or the direct walls from staad to take up most likely in two way action (which i made a regular mesh as per my intended widths. Since i was uncertain with the counterfort bending moment streses from STAAD, i just did it manually.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
White Paper - Moving to a Driverless Future
This white paper describes what we see as the best practices to support a sustainable engineering process for autonomous vehicle design. It exposes how to use simulation and testing in common frameworks to enable design exploration, verification and validation for the development of autonomous cars at a system, software and full-vehicle level to drive a mature product development process for automated driving. Download Now
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
