Contact US
API 650/653 Fillet Weld Base Metal Thickness w/Impact Testing
I need a tank expert. In welding the annular floor plates to the shell plates, where floor plate thickness is 3/8" (P-No. 1, Group 1) and the shell plate is 1-1/4" (P-No. 1, Group 3) and impact testing at -25F is required.................
If the PQR/WPS is generated via a V-Groove test weld, will I be able to make fillet welds on all base metal thicknesses, OR, does the impact testing requirement restrict the minimum base metal thickness as per ASME Section IX QW-403.6 (2017 Ed.)???
The reason for the question is that if fillet weld base metal thickness is restricted per QW-403.6, multiple PQR's will be required (2 PQR's) to cover the range of thicknesses needed for the fillet welds.
CW
RE: API 650/653 Fillet Weld Base Metal Thickness w/Impact Testing
See QW-202.4, which would seem to imply that you'd need another PQR.
You are inded correct. I also found the fine print in Section IX, Table QW-451.4........very bottom line:
GENERAL NOTE: Supplementary essential variables apply when toughness is required by other Sections.
Thank you for your response.
CW
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
