Contact US
Gate valve Balance stem force
Guys,
I’m working on gate valve design with balancing stem.To calculate the force or thrust acting on the stem I used
thrust F = F1+F2+F3
F1 - axial force on gate due to inlet
pressure thru valve bore x coefficient of friction between gate/seat (or valve factor)
F2 - stem piston force
F3 - packing frictional drag force considering packing friction factor
Since the stem setup is a ball screw type
I used Torque required to raise stem = F x Stem lead / 2 *PI * 90% ball screw efficiency.
Now, since I have the balance stem below the gate with gland packing, what should I consider to include this in the calc above to get the net force acting on the stem.
Attached is a sample valve pic for Ref.
RE: Gate valve Balance stem force
The most important and widely varying rest is the 'safety factor' added by experience. For many types of gatevalves and difficult fluids it can be necessary with added force times five or ten.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
