how do I set the mouse wheel to pan when pressed in AutoCad Lt 2018
stadamack
IE
Hello All,
Anyone know how to set the mouse wheel to pan when pressed in AutoCad Lt 2018?
Thank you,
If LT is like regular AutoCAD:
MBUTTONPAN (System Variable)
Controls the behavior of the third button or wheel on the pointing device.
Type: Integer
Saved in: Registry
Initial value: 1
Value
Description
0 Supports the action defined in the customization file
1 Supports panning when you hold and drag the button or wheel
