Anchored sheet pile wall design anchor location
Is there a rule of thumb, or an easy way to find, the proper location (% of exposed or total wall height) of a singe row of anchor tie-backs for a anchored sheet pile wall?
Any thoughts/suggestions would be appreciated.
Thank you.
RE: Anchored sheet pile wall design anchor location
I suppose if you're looking for the optimal location, you would have to find the point on a fixed - pinned beam with an overhang, where the positive moment in the span matches the negative moment on the overhang, under the applied loading, which would then be measured from the point of fixity of the sheet piles. It could be derived (and probably has been somewhere), but it would change depending on the balance between the linearly increasing loads (soil pressure) and uniform loads (surcharge).
Most people would assume a simple span from the bottom of the exposed height to an assumed tieback height, calculate the moment on the simple span, calculate the moment on the cantilever portion above the tieback, and maybe go through a couple iterations to get them to approximately balance. That's what I would do, assuming that practical considerations (ease of construction) on the placement of the tieback didn't take precedence over optimizing the sheet piling.
In single anchored retaining systems, I usually like to keep the anchor close to top or at the top to limit the cantilever type deformations, so effect at the ground surface would be minimal. But, this requires more moment capacity. If you are short on moment capacity, get it lower, however, you should check the deformations, especially ground surface settlements. 20% of the exposed length would be a nice start for parametric analyses.
The best location depends on what shape earth pressure distribution you use, what underground structures or utilities you need to avoid, what soil layer you want to anchor into, what soldier beam steel or tieback tendon size you may already have on hand, etc. Are you trying to balance the moment in the soldier beam or limit the tieback DL? These considerations are all part of the design process. However, for many one-tier anchored or braced walls, I first try my brace or tie location down about 0.35 x the exposed wall height when using trapezoidal earth pressure.
www.PeirceEngineering.com
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
