Formulations for Poulos & Davis (1980) Method for Single Pile Settlement
Hey everyone,
Most of you know the Poulos & Davis (1980) for calculation of settlement of single pile. There are four or five charts. Have you ever seen formulation of these charts? I want to digitize that process, however, I do not want to deal with that extensive effort if there is something similar. Maybe you have created some excel charts?
RE: Formulations for Poulos & Davis (1980) Method for Single Pile Settlement
Interested to follow this.
I digitized a curve from a book before by reading the x and y values from the curve and then created an excel table. I then plotted the values in excel and fitted a trendline to the plot to get the equation. Alternative way to obtain the points is to insert a scaled curve image into CAD and trace it with spline or points and export those points into excel by a lisp. For log scale you can manipulate the date in excel before plotting them so the trendline gives you higher R^2 value.
I know we can digitize it, there are many softwares and web based apps to digitize easily. But the point is if there is anyone to share their formulas, excel files.
I'll get you started
I0=0.97(L/d)^-0.80
RH for L/d=50=-1.63(h/L)^4+11.2(h/L)^3-28.67(h/L)^2-32.64(h/L)-13.11
RH for L/d=25=1.56(h/L)^3-7.88(h/L)^2+13.25(h/L)-6.63
RH for L/d=10=1.62(h/L)^3-8.2(h/L)^2+13.9(h/L)-7.18
I had to do a little research on input values before I could proceed. Poisson's ratio silt 0.3-0.5, sand 0.3-0.4, clay 0.1-0.3, sat. clay 0.4-0.5
and subgrade modulus from NAVFAC DM 7.1-219 Figure 6 is 11.36N-60.67 for clay and 5.70N+13.46 for sand in tons/ft^3. To convert to kPa multiply by 100.
E from Bowles Fdn Eng Table 5-6 sand E=500(N+15). Saturated sand E=250(N+15). Silt&clay=300(N+6) in kPa. To convert to ksf divide by 50.
So Rv=0.34v+0.83 as 500-2000 about same and for k=100 Rv=0.25v+0.88. Rk for L/d=50
Rk=-0.45ln(k)+4.78, for L/d=25 Rk=-0.30ln(k)+3.5, for L/d=10 Rk=-0.17ln(k)+2.4.
Since I was interested in an end bearing helical pile with a slender shaft 25d long in 50 blow silt
I0=0.97*25^-0.8=.074.
Rk=-0.30ln((11.36*50-60.67)*100)+3.5=1.63
Rb=1
Rv=0.34x0.4+0.83=0.97
I=.074x1.63x1x0.97=0.12
Ρ=50Kx0.12/(336K/SFx0.36 ft)=0.05 ftx12”/’=0.6 inches which is less than half expected. Let us know if you have better luck.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
