Light plastic working at 120ºC-250ºF 1
drodrig
DE
Hi there
I am using a metal mould to shape some carbon fiber prepeg into an oven at 120ºC-250ºF
The new prototype is too heavy and I am at the limit of the manufacturer recommendations.
I need to let the hot air flow below it and distribute the weight on the oven bottom so I made a simple support such the one in the picture
Since I can't afford to put in more weight I was thinking about making this support out of plastic.
I checked and the options I found are PEEK (too expensive) and PTFE (not much lighter than aluminium).
Are there any interesting options?
I was thinking maybe some foam, such styrofoam or something stronger such rohacell
What do you think?
thanks
great idea
I didn't think about wood at all
thanks
