MACRO: Publication renaming
spe88
Automotive
Jul 17, 2016
17
I tried to find a macro, which can rename all the publication to the name what it gets its reference from.
e.g.:
sketch name: RW_Mastersketch
publication name: RW_Sketch
I wanna run a macro which rename it to RW_Mastersketch.
Could I have the code of it, it seems not so difficult, but I am not skilled at programming.
Thank you
in CATIA publication options (tools-publications) you can opt for this behaviour...
regards,
LWolf
Has it worked for you? I tried it, I set it to rename always, but nothing happens when I rename the reference. The publication keeps its original name.
it is for creating the publications... once created the feature will get the name of the publication. but it is not meant to work after that.
regards,
LWolf
but yes, it is possible to achieve what you are looking for.
regards,
LWolf
There is a permanent restriction in CATIA that doesn't allow you to rename a publication with code :(. "THIS PROBLEM IS PERMANENT RESTRICTION IN CATIA" See --> HD94249: IMPOSSIBLE TO RENAME A PUBLICATION WITH VB AUTOMATION, The following code will rename the published elements to match the publication, which is less desirable, but does ensure that they match.
Sub publishElementRenam()
Dim uSel As Selection
Set uSel = CATIA.ActiveDocument.Selection
If uSel.Count = 0 Then
MsgBox "Please select a product to rename references for then run again.", , "Error"
Exit Sub
End If
If TypeName(uSel.Item(1).Value) <> "Product" Then
Exit Sub
End If
Dim uPubs As Publications
Set uPubs = uSel.Item(1).Value.Publications
If uPubs.Count = 0 Then
MsgBox "Selected product has no references.", , "Error"
Exit Sub
End If
Dim i As Integer
For i = 1 To uPubs.Count
Dim uPub As Publication
Set uPub = uPubs.Item(i)
uSel.Clear
uSel.Add uPub.Valuation
uSel.Item(1).Value.Name = uPub.Name
Next
End Sub
