Water proofing of buried foundations- can it be avoided in dry ground condition?
I am facing this issue raised from Client and Architects, that if the condition of ground is dry, and ground water table is very deep in the site area, they ask not to water proof the RCC sub-structure (isolated/combined foundations and plinth beams). Please note that there is no basement, and structure is residential-one unit. They ask me to suggest admixture for water proofing in concrete but want to avoid external water proofing to save time(i don't put my trust fully on admixtures). My concern is , that water can penetrate in soil from nearby leakages of plumbing lines, and rain water (though it seldom rains here, once a year) etc.
I have also noticed in many projects of structural assessment of existing structures, that when i get foundation dug for 25 or 30 years old RCC structures to inspect, foundations are always found in good condition, i.e. concrete cover intact and in good condition. I don't observe any waterproofing layer in such cases and see bare concrete surface. It might be the case that waterproofing layer had disappeared/eroded over time? but my point is, that can the water proofing of substructure in dry condition area be avoided?
RE: Water proofing of buried foundations- can it be avoided in dry ground condition?
Yes, in the conditions you described, waterproofing is not necessary. Reserve your waterproofing efforts for things above the ground.
Sounds like waterproofing can be omitted. I've seen waterproofing still used in areas that are dry but there is high risk of sulfate attack from the surrounding soil. I'm not sure if you're in an area where this is a problem.
Omit the waterproofing. Not necessary for your application. You don't need an admixture waterproofing either. As long as your cover on rebar is ok.
Thanks all of you!
eBook - Efficient and Effective Production Support with 3D Printed Jigs and Fixtures
Jigs and fixtures offer manufacturers a reliable process for delivering accurate, high-quality outcomes, whether for a specific part or feature, or for consistency across multiples of parts. Although the methodologies and materials for producing jigs and fixtures have evolved beyond the conventional metal tooling of years past, their position as a manufacturing staple remains constant due to the benefits they offer. Download Now
Overcoming Cutting Tool Challenges in Aerospace Machining
Aerospace manufacturing has always been on the cutting edge, from materials to production techniques. However, these two aspects of aerospace machining can conflict, as manufacturers strive to maintain machining efficiency with new materials by using new methods and cutting tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
