SMath Solver Problem 1
maybe better to attach the input file.....
Deleting out the units from all of the variables (q, L) allow the solve command to run. I'm not sure why the units are stopping the solve command from working, it looked like they were balanced to me. I believe that's where the error is though.
Shotzie... will try that... units are balanced but could be a program issue. Thanks...
Dik
Shotzie... attached.
Thanks, Dik
Thanks IRS... that was the case for the solve.
Dik
After skimming this forum post Link it appears that adding 'ft to the x variable will allow the solve command to run, although I don't believe it will assign units to the "res" variable you've set. I've updated your previously attached file with the change. Not sure if this is the best way to solve the problem but seems to be a workaround for now.
 https://files.engineering.com/getfile.aspx?folder=9fba669e-6cf9-4011-af12-bea3f44babc5&file=Trapezoidal_Load.sm
will try that... again, thanks
Dik
Shotzie... missed that, thanks.
Dik
