Transportation of HSD through LPG pipeline
Dear Sir/Mam,
We are exploring feasibility of transportation of HSD through LPG pipelines. While we are looking into various operational as well as infrastructure requirements, one of challenge that is emerging is the handling of LPG-HSD interface at delivery locations.
Can you please suggest some method to handle the LPG-HSD interface at delivery locations.
Mohit Garg
RE: Transportation of HSD through LPG pipeline
Assume HDS means High speed diesel?
TO avoid flashing the LPG into an interface tank and having to deal with some violent two phase flow / large volumes of vapour, you will need to send the interface to a pressurized vessel able to handle LPG at your pumping temperature and keep it liquid.
What you do with the interface after that is up to you, but I would slowly lower pressure and let the LPG flash off and then use the LPG gas for something useful then pump the HSD into the HSD tank.
I've read of companies using pipeline pigs / pig receivers in these operations in order to reduce the volume of contaminated fluid that needs to be handled at the delivery point. There may be information on the net or from your colleagues in other companies which run these multiproduct pipelines on what type of pig to use.
In reality pigs pass fluid at a rate of about 1%. Following a series of tests which showed little to no impact on the interface size of using pigs or spheres many multi product pipeline companies don't use any physical separation but minimise IF by keeping flow and pressure constant and swapping over products faster in the inlet manifold.
That plus the coast of the pigging and the added risk from the operation male it non preferred.
White Paper – Your Construction ERP RFP Checklist
Selecting business software for a medium to enterprise-sized construction concern is extremely challenging in large part because most enterprise resource planning (ERP) suites originated in the world of repetitive manufacturing and are therefore a poor fit for a project and asset-centric business. However, midsize to large contractors need the predictable, auditable processes that ERP delivers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
