Contact US
Rising Stem Globe not rotating
Hand wheel operated Rising Stem Globe not rotating, when checked Stem got locked with Yoke Bush. Material Stem ASTM A410 Type 410, Yoke Bush A582 Type 416
Will it be due to dust entry into Stem thread.
Will it be due to thread damage due to excess torque
Will it be due to differential expansion of Stem & Yoke Bush thread
Could anybody guide me in finding out probable cause of failure
RE: Rising Stem Globe not rotating
May try to spray WD-40 to the thread.
A good question to the Maintenance.
Hi Isha 90,
The answer is 'yes'. It could be any of the above causes, and in addition not only one alone.
You mention Stem Globe not rotating. Is the stem attached directly to the globe? Could the globe stick to the valve seat?
Regardless of possible causes the most common cause of 'sticking' stem is the use of excessive force and /or lacking routine of testing the valve operation at intervals.
Thank you
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
