Can I use an ACTConsole Snippet to get solid bodies in a geometry group?
I normally group all the solid bodies representing bolts in a model together into a single geometry group. I would like to use a ACTConsole Snippet to get a list of all the bolts in that group. Is that possible? I am currently using this to get the groups in the model:
CODE -->
ExtAPI.DataModel.Project.Model.GetChildren(DataModelObjectCategory.TreeGroupingFolder,True)
Looping through that, I can identify the group I want by getting the group with the "Geometry" as the parent and "bolt" in the name. However, I don't know how to get the children of the group. I think the documentation here might potentially be able to help me, but I don't really know what I'm looking at. Can anyone here point me in the direction I need to go?
RE: Can I use an ACTConsole Snippet to get solid bodies in a geometry group?
CODE --> Python
groups = ExtAPI.DataModel.Project.Model.Geometry.GetChildren(DataModelObjectCategory.TreeGroupingFolder,True)
bolt_group = groups[0]
if "Bolt" in bolt_group.Name:
	bolts = bolt_group.Children
CODE -->
bolt_groups = [group for group in groups if "Bolt" in group.Name]
bolt_group = bolt_groups[0]
bolt_parts = bolt_group.Children
bolt_bodies = [part.Children[0] for part in bolt_parts]
Perfect. Thanks!
White Paper - Effects of AIA Quick Guide to UL 489 or UL 1077
The function of a circuit breaker is to provide overload (thermal) and short-circuit (magnetic) protection to a circuit and its downstream components. A circuit breaker functions like an airbag in a car, protecting circuit components and people by tripping the circuit to interrupt the current flow if it detects a fault condition in the control system. Download Now
White Paper - Guide to Integrate Large-Format Additive
As with any new technology, getting into large-format 3D printing begins with investigation. The first question may be a simple one: what does “large-format” mean? For 3D printers, “large” is a relative term. Many extrusion-based (FFF) 3D printers are referred to as desktop machines, because they fit on table space. Some of these have very respectable build volumes – but when it comes to “large-format,” the machines will need their own dedicated floor space. Large-format 3D printers have significant build volumes and are most often found in professional settings, like manufacturing facilities and R&D centers. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
