Contact US
Thermal Displacement - Bushing into a Housing
Hello All,
I want to calculate the thermal displacement of a pressed fit bushing into a housing. If using the area equation calculation using the equation:
A_f = A(1+2(alpha*delta_T).
Where,
A_f = Final area
A = Current area
Should I use the cross sectional area of the bushing (I think this is right be want to be sure):
A = (pi(d_o^2-d_i^2))/4
or
The "wetted" area:
A = pi*D_o*L
L=length of contact surface between the bushing and housing.
OR
Could this be simplified by a Linier equation:
R_f = R(1+(alpha*delta_T).
Hope this is clear!
RE: Thermal Displacement - Bushing into a Housing
No. Your problem is not clear.
Are you worried about a bushing (material = ???) "expanding" somehow so it gets loose and falls out of the surrounding steel (???) when the original temperature (???) gets hot (final temperature = ???) and the assembly expands?
No equations. you are not yet ready for equations.
What is the original ID, OD of the bushing, original ID of the original (room temperature) machined hole?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
