Transport Road through Wetland/Swamp
Have any of you used the soggy bottom sampler system by AMS?
Here is the link:
https://www.ams-samplers.com/hand-tooling/sludge-a...
I need to perform some shallow auger borings (5 to 10ft deep) along a proposed roadway alignment through a wetland/swamp area. We are not able to get a rig onsite, and I also don't think we will be able to get our tripod equipment setup on the borings. The next option would be to use a hand auger and casing; maybe a 1 3/4" bucket attachment with 2 inch pvc, or something a little larger. I would also supplement some muck probes to help identify depth of organics/muck. Fill heights are minimal, probably 3 to 4 feet.
RE: Transport Road through Wetland/Swamp
If there is some thought that upper soft organic deposits may have to be replaced with better soil, a piston peat sampler and some rod "soundings" might be enough. As I recall commercial one 1" diam peat sampler was a Davis peat sampler. With a little thinking about how to make it work, a 1" diameter conduit fitted with a plug on top with an elongated slot, combined with a piston inside fitted with a pin through the rod works pretty good and is cheap. If one does a lot of these studies, a farm crawler tractor with widened "track base", then with planks bolted to the grousers can go almost any place, including where you can't even walk. Put a cat head on a power take off, use a tripod and you are in business for conventional split spoon borings, SPT sampling.
There is a way to use a tripod some distance from a rig with cat-head. Tie the legs together at the bases and put a pulley down there on the nearest leg. A lot of stretch will be in the rope and it works. Just remember do not try to haul in loose rope with a cat-head. It will wind on in a darn fast hurry.
oldestguy...
Now THAT sounds like the voice of experience...as the rope catches on the cathead drum......been there, done that....lived to tell.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
