Seismic effect- irrigation channel
i am currently designing an irrigation channel which requires application of compression springs along with seismic loads. i have defined seismic loads first (load no. 4). i have used repeat load cases to combine all the loads(https://files.engineering.com/getfile.aspx?folder=...)
In summary, i can see the moments being introduced due to seismic forces but it seems they are not being combined with other load cases. For eg. the forces summary for load cases excluding and including seismic forces is exactly the same (https://files.engineering.com/getfile.aspx?folder=..., https://files.engineering.com/getfile.aspx?folder=... )?
i am unable to exactly pin point the problem as to why earthquake effect is not combining?
RE: Seismic effect- irrigation channel
Could you post the STAAD file? (Or preferably, the text of the Edit file.)
Could you paste the text of the edit file into a post? I cannot get this to work.
EDIT: Never mind.....I was able to get it. Will get back to you.
Ok I think the issue is your seismic load. You are using some sort of generation command that I don't recognize. On my end, I changed that to a self-weight in the X-Direction and it combined the load cases just fine.
When I ran it with the command you are using, it gave the following warning in the output file:
**WARNING: IF THIS UBC/IBC ANALYSIS HAS TENSION/COMPRESSION
OR REPEAT LOAD OR RE-ANALYSIS OR SELECT OPTIMIZE, THEN EACH
UBC/IBC CASE SHOULD BE FOLLOWED BY PERFORM ANALYSIS & CHANGE.
So that may be your issue. It may be just faster to work up a percentage of self-weight and do what I was talking about before.
By the way, are you certain you need a seismic load here? I've never seen one on a trench before. (Of course, then again, I haven't done that many in high seismic zones.)
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper – Choosing the Right Spring Loaded Connector
In today’s cost-sensitive world, designers are often driven to specify the lowest cost solution for every aspect of their designs to ensure that their solution is competitively priced and their company remains profitable. However, specifying a low-cost, low-quality connector solution can result in premature failure, considerable re-work costs and damage to reputations. Download Now
eBook – Own the Lifecycle: Sustainable Business Transformation
Increasingly, product and services companies are seeking more information and control in the operational lifecycle of their products, including service and use. Better information about the operational lifecycle, and the ability to use that information, requires more than just unstructured data flowing back from products in the field. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
