Simulation in creo
sudhakarn
Automotive
IN
I have a doubt in creo simulation.i want to define a switch gear mechanism in creo in which i need to trigger the adjacent part through a surface contact. Could you pls clarify on this?
I would like to add some information on this.basically i would like to trigger one component by the adjacent component.there is no initial contact between the parts and the component is getting pushed by the adjacent part.
Need your help pls.
