How to make an angled cut for the head of a pin
Dlerner
I'm having trouble making the 3d model for this pin. I've tried cutting the sides every which way but all it's doing is giving it straight sides where they have to be at a slight angle. The actual pin diameter is .56" which was not pictured in the drawing. Attached is the real pin I'm trying to make as well as the 2d drawing of the tip of it. Any help would be appreciated.
Thank you
 https://files.engineering.com/getfile.aspx?folder=e5933393-dbc5-4cae-b3f5-86824b288dc2&file=20180821_171608.jpg
Not sure.
In case you do not get any response here in the SW FEA Simulation forum, try posting it in the perhaps more relevant SW 3D design forum.
Create some reference geometry. Create a plane where you need it (you might have to create a few in stages to get where the cut needs to be), then cut with that plane. You have some edges and faces to use as the initial reference.
"I love deadlines. I love the whooshing noise they make as they go past." Douglas Adams
