Error message "No 3D elecment is available to project..."
Bogdan1985
I designed a part and an assembly. There is definitely a 3D element.
I clicked a surface of my part and the error message came up: "No 3D element is available to project.
The model, product or part may be empty....."
Whats happen? Has someone an idea?
See attached image.
 https://files.engineering.com/getfile.aspx?folder=3393452c-530b-4b39-8617-588b2a2def35&file=eRROR-MESSAGE-DRAWING.JPG
So, what were you trying to do when this message popped up?
If you are working with Catia V4 models than you should use aproximation mode as raster. You could change from Tools-Options-Drafting. You loose quality of lines in this way.
