Clad removal technique in rolled shells cylinders
Hello!
Right now we are working with a tower that has internal cladding 316l and monel (0,118"). Per Client requirements we need to weld the internals supports directly to the base metal (SA-516-70 1" thk), so we need to strip back the clad in specific areas to weld the carbon steels supports. Since we have already worked with clad materials in the past, we don't have any problem stripping the clad on the edges of the plates for the longitudinal and circunferential welds or the weld procedure for clad secctions. However this is the first time that we need to remove clad in a shell course already rolled. So I came to you with my first thread to know if there is any machine, technique or recomendantion to remove the cladding on conformed rings or shell course.
JH
RE: Clad removal technique in rolled shells cylinders
Try wrinding to remove clad in a mock-up, then 100% MT in the area.
r6155
Ohhh sorry: I say "grinding"
r6155
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Reliability Verification for AI and ML Processors
Artificial intelligence and machine learning are seeing growing adoption in a wide range of applications. ICs used for AI/ML applications are characterized by large parallel processing computation units, high power dissipation, and complex circuitry that can deliver maximum performance within a strict power budget. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
