I have a horizontal vessel (ASME VIII div 1) that needs to be supported by two points on its cross section, as shown in the attached figure. Its a problem of two localized inward radial loads being applied to a cylinder, I'm not familiar with the WRCs procedures so I do not know if that is the case.
Can anyone point me the section of the code,any methods or the stresses I should analyze?
There is also a stiffening ring inside the vessel acting as a stiffner on this section.
