Name plates on valves according to standard requirements!
Hello!
I was refering to standards ASME 16.34 & MSS SP-25, According to that for every ball valve (for e.g.) there is a name plate i.e. containing basic details of that valves are required to attach with ball valve. For this i have a question that Is it compalsary to attach a SS plate on the valve handle or somewhere on valve! Can we us other options to mark this valve like vibro punching, Lasermarking on body part or on handle so we can avoid losing this plates and losing details of that valve. This kind of problems happens during vavles in bulk put together. (Some companies do not fix it somwewhere on valve but they tie this plates with wires on valves!)
If vibro punching or lasermarking options are good and acceptable then can we say that it is complying with standard for marking of valve that i mentioned!
To be clear only, marking details should be same as on plate and as on other options! I am thinking of an different options only if it can be ok or not!
thank you!
RE: Name plates on valves according to standard requirements!
It's more like a manufacturing question than engineering one. I think the options, such as vibro punching or laser marking, are doable if the machine is available and economically feasible.
@mk3223
thank you for your answer but my only confusion is to know that if we do laser marking or vibro punching then can i say that it is complying to standard marking on valve according to ASME 16.34 & MSS SP-25?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
