SMath - New Found Feature
I can take data that is 'comma separated' and import this into an array, as I see fit...
See the attached example. Looking at importing the complete steel section database, next.
Dik
Dik
RE: SMath - New Found Feature
importData("1:fileName", "2:delimiter", "3:delimiter", "4:delimiter", "5:number", "6:number", "7:number", "8:number", "9:number") - Returns a matrix of loaded data from specified file "1:fileName". Function can be used with 1-9 of the arguments specified. Digit 0 (zero) can be used for the arguments (except "1:fileName") to get the built-in default values. Function is able to read data with manually specified Decimal Symbol ("2:delimiter"), Arguments Separator ("3:delimiter") and columns delimiters ("4:delimiter"). To read a specific region of the data file rows an columns ranges can be requested ("5:number" - start row, "6:number" - end row, "7:number" - start column, "8:number" - end column). To read a data represented symbolically "9:number" can be set to 1.
TTFN (ta ta for now)
Dik
Does SMath work this way?
It would be fun to do a real-time or "near" real-time vibration analysis with SMath Studio. I don't think it has Fourier transforms, yet...
No one believes the theory except the one who developed it. Everyone believes the experiment except the one who ran it.
STF
I'll try inputting the ASCE steel section excel data... an array of 30 or so values for 200 sections, and see how that runs, both for loading and recycling. Stuff I've done is small and time for loading negligible.
When I used to program, I'd have ASCII data files that I used the extension *.adf. I'd search for *.bdf files and if not existing, would load the *.adf file. Import these as variables (usually Type) and immediately store them as binary files aka *.bdf. When running a program and loading data, it was so much faster to load and save the data as binary. This was back before Windows, when machines were much slower... Kept it up with Delphi after windows.
I was able to load the first 116 lines so, a matrix 116x30... had to modify it to remove characters and the program doesn't seem to like nul cells. There is an error in line 117 that I couldn't find.
The data is loaded as soon as I change the filename and hit <Enter> and doesn't seem to slow anything down.
Dik
Cheers
Greg Locock
Dik
The function will not accept an alphanumeric value. Input string error...
It's been fun... next step is to remove the 'W' and 'x' values and to recreate a string variable where the Wzz x zzz column was. Should also be able to modify cells to incorporate units by multiplying the cell value by the unit.
Dik
I found doing some cleanup to the AISC shape database file was worthwhile. I went thru and swapped all the '--' or empty cells to 0 and changed the text from unicode to ansi so there are no more special characters. All pretty easy to do within excel or a text editor but it makes sorting and grouping a bit easier having the 0 in properties that don't exist. I also pulled out the units and definitions as separate csv's and mapped them to the shape indexes.
Open Source Structural Applications: https://github.com/buddyd16/Structural-Engineering
Dik
