Concrete Slab Cover Ideas?
So I am in charge of researching and getting quotes for a concrete slab cover. The concrete slab is about 50' x 100' and is contaminated with chemicals that can't get into the water. So to prevent water from getting onto the pad, like rain, a cover is needed. I wasn't sure where to begin with this as all my searching turns up with polyethylene sheets and not much else.
The cover needs to last about 10 years and should be cheap but durable enough to last for those 10 years. If anyone as ideas on what to look for, or ideas on how to better research this, I'd appreciate it.
RE: Concrete Slab Cover Ideas?
Can you use a polyurethane or epoxy coating with a primer? Cleaning the surface may be an issue. In lieu of polyethylene which will not last, can you use an EPDM material?
Do you have to notify anyone of the contamination. Under relatively recent legislation, Engineers can be held criminally negligent, in Canada, for environmental issues.
Dik
@Dik, reporting the contamination isn't an issue but thanks for the concern. Cleaning is an issue, it's why the cover is what is going to be used. The cover is supposed to be on top the pad, kind of like a roof or like a large tent one might see at a family gathering where people can sit under. Obviously not exactly like that, but I think you get the idea.
I'll look into the EPDM though!
I'd re-post under Chemical Coatings forum.
We have a Chemical Coatings Forum... if it were posted there, I'd have missed it... got it... EPDM is a material used for roofing... it's tough, nearly impervious, and relatively inexpensive and there are numerous roofing contractors in this area that can install it...
Dik
Bespoke FRP cover?
Pre-welded Reinforced HDPE membranes will work and are used for this application. Look into the Cover Up 240 (0.4mm thick)
Cover Up Link
Link 2
How about two inches of WWR'ed concrete?
In situations where contaminated soil must be protected from rain water to prevent spreading of the contamination, a plastic or rubber liner is usually used, and then this is covered with clean soil for ballast and protection of the liner from the elements. In your case, I suggest you to mound some gravel on the pad to avoid water pooling and then cover with a liner and more gravel.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
